rt52
5 years agoMAX10 Read Dual Boot IP core values in simulation
I can successfully perform an RSU using discrete logic implementation on a MAX10 device. I now want to confirm that the correct image has been loaded. My board has the CONFIG_SEL pin pulled up so i...
rt52
5 years agoYes that is correct. I have a requirement to confirm that the Update Image is booting, so I need to be able to tell using the Dual Boot IP core. Currently, my update build just has a different LED pattern, and when that file is downloaded via UART and power cycled, the update LED pattern appears. I just have the Dual Boot IP core instantiated currently, and not connected to anything, in order to compile.
Modelsim is what I am using but I have access to others.
Edit: Re-reading this, I cannot read anything in HW either. Any attempt to read from the Dual Boot IP in hardware or simulation does not work
