rt52
5 years agoMAX10 Read Dual Boot IP core values in simulation
I can successfully perform an RSU using discrete logic implementation on a MAX10 device. I now want to confirm that the correct image has been loaded. My board has the CONFIG_SEL pin pulled up so i...
YuanLi_S_Intel
5 years agoBased on my understanding, you are able to perform RSU with the Dual Configuration IP on MAX 10 in hardware but you are having issue in reading the offset 4 in simulation but not in hardware? May i know are you using modelsim simulation?
