MAX10 power supply 3.3V(+5%,-10%)
- 5 years ago
Yes you can follow then range from the table.
こんにちは、
まず第一に、私がこれをグーグル翻訳で書いていることをあなたに知らせなければなりません。ご質問については、このリンクhttps://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdfの6ページの表6を参照してください。仕様を超える電圧はお勧めしませんWhen VCC is 2.97V (3.3V-10%), isn't it within the range of 3.0V specifications?
- AminT_Intel5 years ago
May I know where did you get that information?
- seiji5 years ago
Hello
I'm looking at Table 6 on page 6 of the spec. I thought this table shows that 3.135-3.465V works with 3.3V specs and 2.85-3.15V works with 3.0V specs.
Therefore, when the external power supply is 2.97V, it is out of the 3.3V specification range, but it is within the 3.0V specification range, so I thought it would work with the 3.0V specification.
Thank you.- AminT_Intel5 years ago
