MAX10 PLL with spread spectrum input
Hello Farabi,
I understand your answer.
I've forget to precise that frequency deviation is about +-250ppm centered, and also frequency modulation about 33KHz.
In my point of vue, 33KHz is more a wander than a jitter, because of low speed of triangle modulation at 33Khz.
Am I wrong?
Did you experience some customer such a DSC63XXB with MAX10 family?
Thanks for your reply,
best regards,
Thierry
Hi Thierry,
Max10 link : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
pls refer to page 27, fINclk input jitter must be below +/- 750ps.
DSC63xxB has 250ppm which converted to ps ~ around 20us = 20000ps.
hope this helps.
regards,
Farabi
- Farabi_Altera4 years ago
Hi Thierry,
I am sorry, my calculation previously was wrong.
If 25MHz input clock with 250ppm jitter, that means is has around ~20ps jitter which meeting MAX10 input clock.
Meaning you can use DSC63xxB for input clock osc.
sorry for the confusion.
regards,
Farabi
