10 years agoMax10 PCB Layout - Unused Pins
Hello, I am building my first from-scratch FPGA project. I’m using a Max10 10M02SC 153-MBGA, but my design is really simple. I really only need to use one bank because I only need about 16 I...
10 years agoOK, thanks, Kevin.
Yes, I am already adding 10 spare I/Os, and I have seen the document you mentioned. Thanks for the info on the clock: I didn't realize that. However, I think I'll be OK in this case. After reviewing the BGA guidelines and my PCB house's specs again, it looks like I will be able to use 8 mil mechanically-drilled vias. I think I can squeeze these in between pads where I need them, so hopefully I won't need to eliminate any pads. Thanks for your good advice! Robert
