10 years agoMAX10 on-chip flash UFM about user data or software alllication
Hello everyone, I have a question about the MAX10 UFM. Now, i want to use flash to store data and niosii software both. However, i don't understand how to do it at same time? Could someone...
10 years agoI'm not sure I understand exactly what you're trying to do... or even if you still have a problem...?
Look at Table 5: "Nios II Processor Boot Options" on page 5 of AN-730. Is what you're trying to do covered by one of the 5 Nios boot options identified in the table? It sounds like option 1 or 2. Figure 2 then shows you where each bit of data will be stored. The section after takes you, step by step, through options 1 & 2. --- Quote Start --- Although it can work now. But i don't know this method is correct or not. --- Quote End --- So, do you have a working system? Assuming it is, and it's covered in AN730 (which I think it might be) then - yes, the method is correct. Cheers, Alex
