Rodo's avatar
Rodo
4 years ago
MAX10, on-board RAM or ROM: What does memory initialization do?
Hi all,
I'm playing with a BeMicroMAX10 that I've had for a while. Last time I used it was in Quartus web (free) v15, now using v21.1.0 (also free).
I was getting an error at compile with error initialization. In the platform designer (old qsys?) I add on-board ROM or RAM and I click the textbox for memory initialization. Anyhow ... I got rid of the error by clicking the box below to give it a name. If I click the boxes or don't click the boxes the total memory bits usage does not change. So, what does memory initialization actually do? I wonder if it really sets the value of each memory cell to a certain hex value? This sounds silly unless it is needed for some reason. When using microcontrollers I always assume the value of uninitialized memory is a random value.
  • YEan's avatar
    YEan
    Hi Rodo,
    Do you have any updates on your question?
    Thank you.
    Ean
      • YEan's avatar
        YEan
        Hi Rodo,
        I think that your issue has been resolved by sstrell.
        I'll now transition this thread to community support.
        If you have a new question, feel free to open a new thread to get the support from Intel experts.
        Thank you.
        Ean
  • sstrell's avatar
    sstrell
    It's an FPGA, so you can program the contents of memories with whatever values you want when you program the device. You need to associate a .hex or a .mif file with a particular memory for this to work, and you can do that in the IP parameter editor for the memory or with a synthesis attribute in your HDL code.
    If you don't have a .hex or .mif file, make sure you disable memory initialization in the parameter editor.
