Rodo
4 years agoMAX10, Nios 2: Intel FPGA Avalon I2C (Master) example ?
Is there a complete example (with buffer connections) of using this IP core in a nios system?
I added the IP core to nios and generated the tri-state buffers with the GPIO Lite core but now I'm los...
ShengN_altera
4 years agoHi Rodo,
I created another sample file attached below which involves interconnection between Avalon I2C (Master) module with example buffer module (verilog) from manual. Hopefully, you have a better understandings on that.
ShengN_altera
4 years agoHi Rodo,
Any further update on this?
Sheng
- Rodo4 years ago
I don't know. I tried to add some code but I think I run out of (internal) RAM so I'm switching to external RAM but I'm having problems getting it to work. I'll go back to I2C when I get the external RAM to work. I suppose you can close this. I'll post a new question if I need to. Thanks.
