MAX10 JTAG programming issue
Hi Daniel,
From your explanation, i understand that you have 2/40 board having issue and the design, setup and etc are identical on all the 40 board. Am i correct?
Also, you mentioned that "We also tried the "Test JTAG Chain" with the JTAG Chain Debugger without success". Are you saying that you cant perform test JTAG chain? or you can but it shows error? any idea on the error?
Yes thats right, we have 2/40 board having issue and the design, setup and etc are identical on all the 40 board.
The Test JTAG Chain shows the error "Error: JTAG Chain problem detected. Error: No device detected."
When we try to program the boards with the .sof or .pof we get the following error messages: "209030 Can't access JTAG chain", "209012 Operation failed".
