8 years agoMax10 Jtag pins as Differential I/O.
Good day. I've got a problem with jtag pin sharing. My device is Max10 10M08. I use jtag pin sharing option and jtag pins as differential inputs. But when I try to program device with sof file us...
8 years ago --- Quote Start --- Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- Thanks for your explanation. It's help me to understand why it doesn't work. But my question about using jtag pins as diff io has no answer. Is it possible somehow? May be using of internal configuration with pof file or two configuration images?
