8 years agoMax10 Jtag pins as Differential I/O.
Good day. I've got a problem with jtag pin sharing. My device is Max10 10M08. I use jtag pin sharing option and jtag pins as differential inputs. But when I try to program device with sof file us...
8 years agoHi,
JTAG pins cannot perform as JTAG pins in user mode if you assign any of the JTAG pins as a differential I/O pin. You must use the JTAG pins as dedicated pins and not as a user I/O pins during JTAG programming. --- Quote Start --- The JTAGEN pin is pulled-up with 10 kOm resistor to 3.3 V. --- Quote End --- Means JTAG pin is used as a dedicated pin. Refer https://www.altera.com/en_us/pdfs/literature/hb/max-10/ug_m10_gpio.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
