MAX10 "JTAG_Lock_Unlock"
Hi Johny,
Once the secure mode is LOCKED, the only way is to UNLOCK it using the internal JTAG block so that the JTAG can be used again. It can be seen from the design attached previously.
For your scenario, i am afraid that it cannot be programmed with JTAG anymore. The only method is the remove the flash, program it with the encrypted bitstream with internal JTAG block IP in the design.
Thank You.
Hi YuanLi_SIntel,
As far as I know the only way to implement sof or pof files into MAX10 is JTAG. I have compiled the project ("JTAG_LOCK_UNLOCK"). I can make the encrypted bitstrim pof-file. So I still can not realize how can I implement into chip my pof-file by help of internal JTAG in such way? And what do you mean writing REMOVE THE FLASH? Excuse me for my importunity, can you explain me more detailed?
