9 years agoMax10 initialize ram/rom
Hi, I'd like to know (datasheet are so confusing): for max10 devices Is it possible to initialize ram/rom data when programming bit stream with jtag? Is it possible to initialise ram...
9 years agoI think it depends on what configuration you have chosen in Assignments/device/device and pin options/configurations.
If it is configuration with memory initialization, then you can probably init the device with an .hex file. Otherwise, the syn/par will give you error if you try to provide an .hex file to the BRAM block.
