MAX10 GPIO Lite DDR Input Error
Thanks for your reply.
I have read all possible related documents but haven't find any information that DDR input is not supported at this specific pin. Interestingly other pins around this pin i can use as DDR inputs but this specific pin not. So as a last resort i have ended up on this forum for any precise clue/information.
Have you checked other specs as well? The device IO standards, range of voltage, etc? That could give the same error as well
Thank you
- _MZ_4 years ago
Yes everything checked. Pin 46 is is present in Bank 3 and all the banks are provided with 3.3V and in the Pin Planner it is set to 3.3-V LVCMOS. This input is interfaced with a chip and receives data.
- AminT_Intel4 years ago
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
