MAX10 GPIO Lite DDR Input Error
You probably received that error due to out of specs setting. Please refer to our Max 10 documents on your design. You can refer to these two documents to begin with:
1. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_gpio.pdf
2. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf
- _MZ_5 years ago
Thanks for your reply.
I have read all possible related documents but haven't find any information that DDR input is not supported at this specific pin. Interestingly other pins around this pin i can use as DDR inputs but this specific pin not. So as a last resort i have ended up on this forum for any precise clue/information.
- AminT_Intel5 years ago
Have you checked other specs as well? The device IO standards, range of voltage, etc? That could give the same error as well
Thank you
- _MZ_4 years ago
Yes everything checked. Pin 46 is is present in Bank 3 and all the banks are provided with 3.3V and in the Pin Planner it is set to 3.3-V LVCMOS. This input is interfaced with a chip and receives data.
