11 years agomax10 dual image + dual hex for nios
Hi All, Is it possible to make dual image configuration with separated hex image for nios in each ? Question is related to situation when you need to perform safe remote update of nios firmware ...
9 years agoHi there,
I have the same problem. Dual configuration (two *.sof) and two files for a NIOS in each configuration. Is there a built-in function that creates a *.pof file out of that? @Andi: Do you have a little bit more detailed instructions on how you did that. How did you set the reset vectors? Anything needs to be changed in Eclipse? Best Regards
