11 years agomax10 dual configuration
I might be missing something but it doesn't seem possible to select dual configuration with memory initialization in any of the max 10 devices. Can anyone confirm this?
If true this seems to be a disappointing limitation as it means it is not possible to implement a nios design using dual configuration.1 Reply
I filed a service request to check and Altera confirm that dual configuration with memory initialization is not supported on the Max 10. However they said it is possible to implement a Nios dual configuration design by using the user flash memory (UFM) ip.
