EEren's avatar
EEren
8 years ago
MAX10 Dual Boot.
On CFM0 I have a bootloader. I create rpd file from a main project and burn it on CFM1.
After successful burning I switch BOOT_SELECT to boot from CFM1. However the main project
failed to run and the boot runs.
Where can I find some instructions how to create valid rpd file and burn it into CFM1.
  • EEren's avatar
    EEren
    Hi Anand
    Thank you for the example.
    I have something to clarify
    for(address=CFM1StartAddress;address<=CFM1EndAddress;address=address+4)
    scanf("%2x%2x%2x%2x",&receivedHex[0],&receivedHex[1],&receivedHex[2],&receivedHex[3]); /*Get 4 bytes from UART Terminal*/
    for(byte=0; byte<4; byte++)
    receivedHex[byte] = (((receivedHex[byte] & 0xaa)>>1)|((receivedHex[byte] & 0x55)<<1));		/*Swap LSB with MSB before write into CFM*/
    receivedHex[byte] = (((receivedHex[byte] & 0xcc)>>2)|((receivedHex[byte] & 0x33)<<2));
    receivedHex[byte] = (((receivedHex[byte] & 0xf0)>>4)|((receivedHex[byte] & 0x0f)<<4));
    word = (receivedHex[0]<<24)|(receivedHex[1]<<16)|(receivedHex[2]<<8)|(receivedHex[3]);	/*Combine 4 bytes to become 1 word before write operation*/
    	IOWR_32DIRECT(ONCHIP_FLASH_0_DATA_BASE, address, word);					/*Command to write into On-Chip Flash IP*/
    	byte = 0;
    	word = 0x0;
    	while((IORD(ONCHIP_FLASH_0_CSR_BASE, 0) & 0x0b) == 0x02)
    			  	printf("Writing CFM1(%d)\n",address);
    		if((IORD(ONCHIP_FLASH_0_CSR_BASE, 0) & 0x0b) == 0x00)
    			  		printf("Write to %d failed\n", address);
    			  		state=20;
    			  		address = 700000;
    			if((IORD(ONCHIP_FLASH_0_CSR_BASE, 0) & 0x0b) == 0x08)
    This part
    I shouldn't do if I have Big-Indian option or I should swap MSB and LSB anyway?
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    1. Bit reversal is required if you have used little-Indian option while generating the .pof file. Which is default.
    2. If Big-Indian option is used bit reversal is not required
    3. Example design is attached
    Anand Raj Shankar
  • EEren's avatar
    EEren
    I write the rpd file. Let's take the first bytes from the file 50 FF 47 FF. But when I read it back from the flash I get FF 50 FF 47.
    What's going on! Who can me explain for for Christ's sake!
    AnandRaj_S_Intel
    1. Project related to dual configuration should be configured as double image.
    2. Should I reverse bytes before programming? No.
    For more information please check the below links.
    https://www.youtube.com/watch?v=0k4AZmdW9Sk
    https://www.youtube.com/watch?v=Z0l0GrjXn8w
    Anand Raj Shankar
  • EEren's avatar
    EEren
    May be I burn in the wrong sector? in my module flash_update generics are
    SECTOR3_START_ADDR         => 16384,
    SECTOR3_END_ADDR             => 114687,
    SECTOR4_START_ADDR         => 114688,
    SECTOR4_END_ADDR             => 188415,
    SECTOR5_START_ADDR          => 188416,
    SECTOR5_END_ADDR              => 360447,
    As I understood SECTOR5 is CFM0 and SECTOR3-SECTOR4 is CFM1.
  • EEren's avatar
    EEren
    prd file is a binary file. should I reverse bytes before programming? and what is the order of bytes?
    this
    word_to_write = (UInt32)((reversed_byte[raw_data[i]] << 24) | (reversed_byte[raw_data[i + 1]] << 16) |   (reversed_byte[raw_data[i + 2]] << 8) | reversed_byte[raw_data[i + 3]]);
    or this
    word_to_write = (UInt32)((reversed_byte[raw_data[i + 3]] << 24) | (reversed_byte[raw_data[i + 2]] << 16) |   (reversed_byte[raw_data[i + 1]] << 8) | reversed_byte[raw_data[i]]);
  • EEren's avatar
    EEren
    I did as described in the document. However it dosen't work after programming prd file into CFM1. The master project should be configured as a single or a double image?
    AnandRaj_S_Intel
    Refer the links and demo projects.
    AN 730: Nios II Processor Booting Methods in MAX 10 FPGA Devices
    https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/dualboot-design-example/
    https://fpgawiki.intel.com/uploads/0/00/Using_Dual_Boot_MAX_10_Evaluation_Kit.pdf
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an741.pdf
    Anand Raj Shankar
