MAX10 Damaged with clk pin pulled down
On my new design, I observe recurring FPGA MAX10 failures. The board has 6 similarly polarized FPGAs 10M08SCU169I7G . The FPGAs are programmed correctly, run fine for a few hours and then one of the 6 breaks for no apparent reason. After replacement, the card is functional again and I no longer observe any failure.
On two occasions, I observed a similar failure, the clock signal seems to be pulled low by the FPGA. The clock pin used is a CLK0n, or CLK1p used in 0-3.3V and configured in 3.3 V Schmitt Trigger
I did not observe any other pins pulled low.
I would focus more on the production problems of the card, however, I am surprised to observe the same failure several times. Do you know of any problem of this type? Do you have any leads to guide us?
Thank you
1 Reply
- JonWay_altera
You might want to
1) Check if there is any chance you have violated the absolute max spec: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/m10_datasheet.pdf (Table 4)
2) Check if it could be due to ESD.
