Max10 CRAM configuration with RPD file via system console/host CPU
MAX 10 FPGA does support Remote System Upgrade feature. You may like to refer to the following document on options available to do this.
It also provide links to a RSU example. It is also possible to access RSU block through user logic, which in your case will be based on SPI interface (link provided in above document).
Please note that CFM/UFM requires a .pof file.
I looked at that before submitting questions.
In Quartus, platform designer DOES NOT highlight “remote Update IntelFPGA IP” under the IP Catalog Configuration and Programming for selection if MAX10 selected as device.
The section 3.5 (Accessing Remote System Upgrade through User Logic” too light to understand in depth of anything. If there are reference design or application note beyond helps.
The RSU example provided is for UART with NIOS based RSU and not with user logic (no NIOS).
Maybe you can point me to the RSU example of USER LOGIC.
