Max10 CRAM configuration with RPD file via system console/host CPU
I looked at that before submitting questions.
In Quartus, platform designer DOES NOT highlight “remote Update IntelFPGA IP” under the IP Catalog Configuration and Programming for selection if MAX10 selected as device.
The section 3.5 (Accessing Remote System Upgrade through User Logic” too light to understand in depth of anything. If there are reference design or application note beyond helps.
The RSU example provided is for UART with NIOS based RSU and not with user logic (no NIOS).
Maybe you can point me to the RSU example of USER LOGIC.
- jozephka994 years ago
Contributor
If you are using 10M02 family or SC subfamily you cannot use dual configuration features. If don't you can refer: https://community.intel.com/t5/Programmable-Devices/MAX10-RSU/m-p/1346476/highlight/true#M82672
