MAX10 correct VCCIO when using LVDS
Hello FvM,
thank you very much for your reply, do you know if there is a risk of hardware failure? or is somewhere, in Intel documentation, internal structure of LVDS pins defined? I am really struggling to find it. Might be interesting to know what is behind reduced performance.
From what we see, as we have VCCIO powered by 3.3V (unfortunately), the mid point of a LVDS bus is around 1.6V, so there seems to be ratiometric circuit depended on VCCIO -> by using 2.5V it will be 1.2V, as should be according to LVDS specification.
Thank you
Have a nice day
Michal
- FvM2 years ago
The keyword in my previous post is "unsupported". Therefore you can't expect specifications about performance etc. You need to evaluate operation parameters on your own. Common mode output voltage, also differential voltage will be increased with 3.3 V supplied FPGA LVDS driver, most reveivers tolerate it.
