ChetanKarkera's avatar
ChetanKarkera
3 years ago
Max10 Conf_done pull-up resistor value
I have a requirement to connect LED to CONF_DONE pin to indicate the status of configuration. Is it fine to connect a LED directly to conf_Done pin with current limiting resistor around 300 ohm, or do we need to adhere to the 10Kohm resistors as mentioned in the datasheet?
  • We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
  • Hi,
    You may try to use the lower value however we recommend to follow the datasheet as it has been tested by Intel.
    Aiman
