ChetanKarkera
3 years agoMax10 Conf_done pull-up resistor value
Hello, I have a requirement to connect LED to CONF_DONE pin to indicate the status of configuration. Is it fine to connect a LED directly to conf_Done pin with current limiting resistor around 300 ...
NurAiman_M_Intel
3 years agoHi,
You may try to use the lower value however we recommend to follow the datasheet as it has been tested by Intel.
Aiman
