SVran
6 years agomax10 compile warning ID=169202 inconsistent VCCIO across multiple banks of configuration pins >> How to solve this ?
Dear, 10M08SCU169I7G with vccio1B=1.8v; vccio8=3.3V (vccio1a=2.5v)Configuration pins are in banks 1B + 8 Quartus prime 18.0 standard build 614 Warning (169202): Inconsistent VCCIO across mult...
SVran
6 years agoHello Shafiq,
Pin-planner signal list shows vccio1b=1.8 and vccio8=3.3 because I defined these io-standards on their signals in assignment-editor.
assignments > device > device and pin options > configuration : in this screen I tried with box checked/unchecked "Force Vccio to be compatible with configuration IO-voltage: but this gives no difference .... I don't see anything else I that relates to Vccio 0 config pins ? ?
Stefan
ShafiqY_Intel
6 years agoHi Stefan,
The issue is the configuration pins are powered by different Vccio.
Have you tried use the same voltage for I/O bank 1B and I/O bank 8? If yes, is it able to solve the issue?
