9 years agoMAX10 Compilation Report
This is a Compilation Repor Flow Status Successful - Tue Feb 28 14:26:56 2017 Quartus Prime Version 16.1.0 Build 196 10/24/2016 SJ Lite Edition Revision Name ...
9 years ago --- Quote Start --- Actually my top entity pins are not populated yet. --- Quote End --- You should have mentioned this earlier. It makes the previous discussion pointless. Any logic that doesn't affect an output pin or a JTAG test function directly or indirectly will be discarded. Also any logic that doesn't change state because it misses the clock connection or is hold permanently in reset. The behavior is not specific to Quartus 16 or MAX10.
