10 years agoMAX10 ADC doesn't start during power on
I'm using MAX10 ADC to measure on board voltages. The ADC IP operates normally when the design was programmed using JTAG USB Byte Blaster with SOF file. When same design is programmed using POF fil...
9 years ago --- Quote Start --- Hey johnboy, I tried to contact you because of the MAX10 files. But unfortunately your mail account is not longer available. Are still active in this forum? Regards Mathias --- Quote End --- YES, I have worked on the MAX10 ADC. It doesn't work well, an external ADC works better, much better. I used QSYS to get the basic files for the ADC Core only and hooked up my self. It works using SOF but not using POF. Just the ADC does not work with the POF, the rest of my code works fine.
