10 years agoMAX10 ADC doesn't start during power on
I'm using MAX10 ADC to measure on board voltages. The ADC IP operates normally when the design was programmed using JTAG USB Byte Blaster with SOF file. When same design is programmed using POF fil...
10 years ago --- Quote Start --- Hi johnboy, Thanks for your reply. That's okay if you can help me with this next week but please kindly do post next week. In the mean time I will try to figure out how to make this work. Thanks, --- Quote End --- OK, if you send me your email I will blast you a bunch of files I used to make the MAX10 ADC work. [email protected]
