10 years agoMAX10 ADC doesn't start during power on
I'm using MAX10 ADC to measure on board voltages. The ADC IP operates normally when the design was programmed using JTAG USB Byte Blaster with SOF file. When same design is programmed using POF fil...
10 years ago --- Quote Start --- YES, I was able to get the MAX 10 core only ADC working. BUT the ADC is not great and finally I used an external ADC from Analog Devices, much better. The Max 10 ADC needs a bunch of Verilog stuff buried in the Altera's Qsys. Altera does not seem to help with this mode. I have a bunch of files, but will not be able to help you until next week. --- Quote End --- Hi johnboy, Thanks for your reply. That's okay if you can help me with this next week but please kindly do post next week. In the mean time I will try to figure out how to make this work. Thanks,
