10 years agoMAX10 ADC doesn't start during power on
I'm using MAX10 ADC to measure on board voltages. The ADC IP operates normally when the design was programmed using JTAG USB Byte Blaster with SOF file. When same design is programmed using POF fil...
10 years agoI probed around and found that a PWRDOWN signal in a FSM was always hi, thus keeping the ADC off when .pof is used, but ok when .sof. What is happening??? Is this an Altera problem??
