10 years agoMAX10 ADC doesn't start during power on
I'm using MAX10 ADC to measure on board voltages. The ADC IP operates normally when the design was programmed using JTAG USB Byte Blaster with SOF file. When same design is programmed using POF fil...
10 years agoI have the same issue, with a 10m50 MAX 10 adc. The .sof works fine but the .pofadc does not! YES I am using the correct files. I connected VCCIO1A and B to the same rail, but no success. I have noticed that the 'power down' flag is set, what is that? I found this in the Verilog files for the adc.
I have tried a DECA board and it works fine, I have also tried a BeMicro board and it works fine in both .sof and .pof modes. NOTE: the power rails for the DECA and BEMicro are different, I tried both on my board with no luck... YUCK....
