10 years agoMAX10 ADC doesn't start during power on
I'm using MAX10 ADC to measure on board voltages. The ADC IP operates normally when the design was programmed using JTAG USB Byte Blaster with SOF file. When same design is programmed using POF fil...
10 years agoAre you convinced you're using the right .sof to generate your .pof programming file? If you have part of your design behaving as expected might you have incorrectly used a previous, older .sof file?
I've never experienced a .sof / .pof discrepancy as you describe. Cheers, Alex
