MAX10 About absolute maximum rating
What is the Absolute Maximum Rating voltage for analog input pins on the MAX10 Dual Supply Devices?
If Prescalar disabled and a voltage higher than the voltage value of the VREF pin is applied to the analog input pin, how many volts is allowed?
- AminT_Intel
That will depend on user's configuration. Please refer to page 15 from this link https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf
Thank you.
- ken-salt
Hi!
The link page lists the power supply.
The question is not the power supply, but the maximum absolute rated voltage of the analog input pins and the allowable voltage when VREF is exceeded.
Best regards
- AminT_Intel
Thank you for emphasizing your point. You can refer to page 31 VREF I/O Standards Restriction, and page 32 for Voltage Maximum Rating (for 3.3 V or 3.0 V) from the document from this link: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_gpio.pdf
Please let me know if you need more information.
