9 years agoMAX10 10M04SA Consuming Too Much Current In Idle
I have a custom board with a 10M04SAE144. It has a switching power supply, TI's TPS54229 converting +5V to +3.3V for the FPGA. With the external oscillator disabled and a dummy *.pof file loaded into...
9 years agoI'm presuming you looked at this:
https://www.altera.com/en_us/pdfs/literature/hb/max-10/m10_datasheet.pdf You say there are I/O's set to float. Are you referring to the unused pin setting in the Device settings (Device and Pin Options)?
