14 years agoMAX V "Jtag chain problem detected"
Hello I build a testing device - another one (first works fine). One of the testing steps is programming CPLD Max V 5m80z. All signals have been connected but I have a problem. I tested connect...
14 years agoYes, I found the issue. The ground signal in my PCB is not got. I mean the routing is bad, not the connection. There is quite big current flowing through ground line which goes to JTAG connector from others parts on PCB. I cut this path and connected programmer directly by bypass (simple wire). It works perfectly. :)
