Max V I2C hardware connection
You mentioned "Max V does not have dedicated I2C slaves. If you'd like to use it, you will have to develop controller inside of the FPGA." But that does not answer if I2C can be connected electrically to any of the I/O pins. When I said connect electrically, I mean the physical pin of MaxV. Can MaxV I/O pin be connected directly to an I2C or does it need an external I2C to LVTTL translator?
From my last post, developing a controller meaning writing an RTL for that. Once you have done that, the pins should be connected with right IO standard according to the Max V datasheet.
Thank you
- AminT_Intel4 years ago
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
