19 years agoMax speed of capture of analog data
Hello! What Max speed of capture of analog data we can achieve using Altera FPGA devices? Digitized data will be stored in memory and then to be transferred through PCI-E. What max bandwidth o...
19 years ago --- Quote Start --- Hello Gregor! I'm going to use Atmel ADCs. What do you think about realizing multiplexor in FPGA to switch between ADCs(and increase sampling so). Will be it work precisely? Thanks! --- Quote End --- If you by that refer to interleaved sampling of one analogue signal using two or more adc's with offset clock, then there is no reason why it would not work ON THE DIGITAL SIDE, but if the sampled data are going to be useful is a completely different story. It requires a good match of the ADC's, the amplifiers and the clocks. It all depends on your requirements. Digital post correction and calibration could maybe help. I think oscilloscopes have been doing that for years. Personally I would try to avoid multi-adc solution and find another adc if at all posible.
