19 years agoMax speed of capture of analog data
Hello! What Max speed of capture of analog data we can achieve using Altera FPGA devices? Digitized data will be stored in memory and then to be transferred through PCI-E. What max bandwidth o...
19 years agoHere's a system that samples at 1GHz:
http://www.ovro.caltech.edu/~dwh/correlator/index.html I was at the Embedded Systems Conference class given by the designer (David Hawkins) and the system in the above link is being replaced by a Stratix II based system that will do 983 TMAC/s. As far as the maximum bandwidth of the DDR-II and PCI-e, you can determine these pretty quickly through their respective data sheets. Although, maximum bandwidth, and real-world data throughput are two different things.
