19 years agoMax speed of capture of analog data
Hello! What Max speed of capture of analog data we can achieve using Altera FPGA devices? Digitized data will be stored in memory and then to be transferred through PCI-E. What max bandwidth o...
19 years agoYou need to use an ADC external. The sky is the limit on how much data you can capture and is only limited by your ability to process or transfer that data.
Can you give a little more detail about the analog signal you are trying to capture?
