19 years ago
MAX II Project Ideas
I think MAX II is a great device, with lots of features (for a CPLD) and easy to use. I am considering doing my Masters project using MAX II. Any good ideas or suggestions? I have a MAX II dev kit. Thanks.
    --- Quote Start ---
    Thanks guys. All the ideas sound interesting. :)
    I am thinking of using the MAX II to do a data logger. The MAX II G parts have low power consumption and I can use the User Flash Memory to store the data. Probably I can use the data logger to record the temperature at a specific interval.
    Also, I can write a Visual Basic program to interface with the MAX II to read out the data. Previously I did use the RS232 serial communication to interface the PC with a microcontroller. But now I am thinking of using USB as the communication interface to read out the data from the MAX II. I will probably need a FTDI chip as well. Anyone tried the MAX II + USB interface? I think that would be cool. Thanks. :)
    --- Quote End ---
    Email me, I have a really basic design which targets an FPGA but you could reuse it for a MAX part. I used the FT245 chip and made a host side program that I sent a file to and from the FPGA. Nios II was reading data from USB then firing it straight back over USB and it was able to send a 1MB word document back and forth in around 10 seconds.... I think it's been a while.
    The design is really rough but it'll get you started. I think my USB "controller" was 30 LEs so it's fairly lightweight. It's not really a controller, I was just retiming the USB interface to stitch it up to an Avalon-MM slave port.
    Thanks for the tips! Looks like I need to build my own board as I want to use the MAX II G device which has a lower voltage requirement at 1.8V.
    If I remember, the MAX II dev kit has a USB type 2 connector on it. I could be wrong but I think it has the schematics and the FTDI chip on there as well. The board can be powered via the USB interface.
    I just grabbed this text from the start guide for the kit:
    The USB Reference Design provides an example of how to connect a PC
    to the MAX II development board using the on-board USB MAC from
    Future Technology Devices International (FTDI). The design consists of a
    Visual Basic Application and a Quartus II project. Source code for both
    projects is included on the MAX II Development Kit CD-ROM.
    I'm not sure if this helps you.
    I was going to try to implement a low end processor core in a Max II part. Perhaps the good old Commadore64 architecture would be a good one to go for. The C64 if I remember correctly had the following registers:
    A (data 8 bits)
    B (data 8 bits)
    D (A and B registers stuck together for 16 bit operations)
    X (index 16 bits)
    Y (index 16 bits)
    PC (program counter 16 bits)
    SP (stack pointer 16 bits)
    Then you can reuse the old ROM, compilers (basic), ...... Space Taxi :)
    How about a video game using the LCD module and the push buttons?
    Or get a SantaCruz VGA module and do something driving a monitor?
    Or wire up an a/d module to it and do some kind of data acquisition that reports to the PC via USB. Or PCI. It could monitor temperatures or something like that. Combine this with a power controller and the MAX II device could control a little robot or something like that.
    Altera had a Nios II design contest in 2005. this link shows the papers:
    http://www.altera.com/literature/dc/lit-design-contest.jsp
    While Nios II doesn't run in Max II, looking at these may give you an idea.
    Good luck!
    Gregor
    A lot of possibilities especially if you want mix some A/D and software. You can use USB on the dev kit to interface some SW you make to the device/kit.
    Encryption/decryption.
    Look-up table based A/D applications.
    I'll think about it.
