9 years agoMAX FPGA/CPLD capable of dynamic signal shifting, 3.3v -> 1.8v on same GPIO?
Wondering if the MAX series 10 FPGA or 5 CPLD are capable of dynamic signal shifting on the same GPIO. Ex. signaling at 3.3v for initialization and then switching to 1.8v for data transfer?
9 years agoThe forum deletes my post every time I try to link a related post.. not sure why..
--- Quote Start --- Are you proposing to change the voltage at which the I/O bank in question is powered after initialization, before data transfer? Unusual, but I don't see why it won't work. You can't really do so without changing the voltage. The MAX device can't drive out at a 1.8V I/O standard if the I/O bank is powered at 3.3V (and vice versa). Driving a 3.3V signal into a 1.8V powered bank is probably not acceptable either - check the datasheet. From memory, you can drive a 3.3V signal into a 2.5V powered bank, but not if it's powered at a lower voltage. Assuming scenario 1, the only* issue I can think of is timing analysis, which Quartus will only do based on one set of I/O signalling standards. So, you'll be operating, in part at least, out of spec. This may not matter. Perhaps your initialization is slow enough such that constraining your design for your data transfer mode of operating is adequate. You'll also have to be careful how you change the voltage on the bank. Check that the bank in question isn't included n the FPGA's POR state machine. Bad behaviour on such a bank's voltage could cause your device to reset. * there may be other issues... Cheers, Alex --- Quote End --- Thank you! I read this application note Altera MAX Series as Voltage Level Shifters (https://www.altera.com/en_us/pdfs/literature/an/an490.pdf) and it says the MAX 10 can output different voltage signals on different I/O banks - would it be better to have two I/O banks connected in parallel with a diode to the interface? That way I can switch voltage levels from 3.3v -> 1.8v after initialization without resetting the chip or messing with the system voltages that are setup and seems to be within the spec of the tools. (Btw.. it is for this project alteraforum.com/forum/showthread.php?t=54866 ) Alternatively, I think this could be done in an FPGA and that might save an re-spins or patch wires.. thats probably the better solution though more expensive up front.
