17 years ago
Max 7000: Epm7064s-5
We've been using an EPM7064S-TC44-5 with an external 100MHz clock for a while but now we have a need to increase the clock speed for our device. From the datasheet, the 7064S-5 has a fmax of 250MHz and a fcnt of 175.4MHz...assuming I understand it correctly, the important max speed is 175.4MHz but you can supply it with up to a 250MHz clock and it'll just run at 175.4MHz. First off, is that assumption correct?
Second - any recommendations on a clock for this? (and where to buy it) Its important that it's a 5V clock also. I've been searching for a good clock solution and so far I'm not finding much.
Any thoughts would be very much appreciated.
Thanks!
    Yes, it's somewhat clearer than "highest frequency for pipelined data" in the datasheet.
    I'm not completely sure
    - You can implement combinational logic at a higher frequency
    - A non-feedback register can possibly use a clock frequency up to fmax
    I don't think, that it makes much sense to push MAX7000S to the limits. You most likely won't find a 5V crystal
    oscillator above 125 or 133MHz and have to use an ECL or LVDS oscillator or a discrete solution with a level
    translator. Also the dynamic power dissipation is rather high for the 5V node. With recent CPLD, you can achieve
    fcnt of 200 to 300 MHz.
    So what's the point of the fmax value given in the datasheet if you need to respect the 175MHz fcnt value instead?
    --- Quote Start ---
    --- Quote End ---
    Clearly wrong. Synchronous registers must be exptected to stop operation above max fcnt.
