MAX 3000 product code
- 4 years ago
Those devices could be preprogrammed with code that is incompatible with your hardware design.
So you could not necessarily put them on your board and expect to then program your design via JTAG.
If you reprogrammed the devices BEFORE putting on your board then that issue could be mitigated.
Hi Paolo,
As far as I concern, since the additional suffix is referring to customer specific order, the material was built based on some specific customer request. There are also another case where they have undergone additional qualification upon request and additional suffix was added. It means it will be different for each cases happened for some devices.
Specifically for your case, what I can say it may or may not compatible with the standard one. However, I have compared some key specifications of both EPM3064ATC44-10N and EPM3064ATC44-10NAF and found no difference.
Aqid Ayman
