11 years agoMax 10
Hello! Does anyone know when will altera provide support for MAX 10 SA series FPGA? I cant find any BSDL file, package dimmension, early power estimator and many more. Why did they release devi...
11 years agoHi.
wasn't the support for MAX10 FPGA added with the update to QII 14.0 available for download at altera.com? Besides this all alreday provided like datasheet, pinout, ... is listed at MAX10 device section on altera.com, try http://www.altera.com/literature/lit-max-10.jsp :-) The VCC_ONE option is listed in the pin connection guidelines as an option to connect all VCC Pins (I/O and core) to 3.3V and use an internal 1.2V core voltage regulator to minimize the external device count. Besides this option you can still connect I/O and core separately as also defined in the PCG.
