9 years agoMAX 10 True LVDS Tx where are you??
I'm having some issues trying to id the True LVDS Tx pins on the MAX10, 10M04SCU169. I have looked at the datasheet "MAX 10 High-Speed LVDS I/O User Guide" and it says that the bottom bank 3 has true...
9 years agoThe answer is clearly given in the 10M04SC pinout file, which shows DIFF_IO_TX_RX pairs B1, B3, B5, B7, B9, B10, B12, B14 and B16 as dedicated LVDS outputs. I'm quite sure, the difference between dedicated and emulated outputs is also visible in the Pin Planner.
