ARitt
7 years agoMAX 10 Sample & Hold Timing
The MAX 10 A/D block diagram shows a sample and hold function before the A/D. Unfortunately, there is no documentation of the timing for the S/H function. When sampling a complex signal, it is impo...
KhaiChein_Y_Intel
7 years agoHi Aritt,
This function is in the IP, user has to concern only the parameters of the entire IP. According to the user guide, 500kHz is one of the allowed values for sampling rate. As long as the value is an allowed value for the sampling rate, you will be able to see the expected result.
