MAX 10 PLL input and output clocks warnings
- 5 years ago
Hi Ash,
Thanks for this, thats all good now. I also found i had declared the input clock as a global clock which it did not like ... i assume because it no longer exclusive to the PLL input. With that and your notes above i no longer get these warnings.
Many thanks for your help.
Ian
Hi Ian,
You can assign location to the PLL instance in the Assignment Editor.
1) Go to Assignment Editor.
2) Double click on <<new>> row in To column.
3) Using Node finder, select the PLL instance.
4) In Assignment Name column, choose Location.
5) In Value column, first select the Element as PLL and then the Location as desired.
The PLL_CLKOUT pins are named as B-Bottom, R-Right, L-Left and T-Top based on PLL locations in the package. Please refer Figure 10 of Intel MAX 10 Clocking and PLL User Guide for the PLL locations: https://www.intel.com/content/www/us/en/programmable/documentation/mcn1395213337540.html#mcn1395713558787
Regards.
