StevenBE
8 years agoMAX 10 pin status during startup and JTAG programming
What is the status of the IO pins during startup and JTAG programming? Tristate? I'm driving NMOS fets with the MAX10. I have to be 100% sure the FETs remain off during startup and programming. Wi...
AnandRaj_S_Intel
8 years agoHi,
- All I/Os pins are tri-stated until device into User- Mode.(It depends on the ICB Values)
- Yes, FETs remain off during startup and programming. Weak pullups are often fine for digital input. So you can use pull-up options.
- Each I/O pin provides an optional programmable pull-up resistor during user mode. The pull-up resistor, typically 25 kΩ, weakly holds the I/O to the VCCIO level.
Assignments-> Settings -> Compiler Settings -> Advanced Settings (Fitter) ->Weak Pull-Up Resistor option
Anand Raj Shankar
