10 years ago
MAX 10 Pin Questions
I am working on design using a Altera 10M50SC device and have a few questions regarding pin types.
First, this file https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/max-10/10m50sc.pdf specifies no IO performance for pins 50,58,62 and 135. What is the IO performance of these pins?
Second, I have run into trouble with Cyclone V single-ended clock input pins where only the _p input could be used single ended. With this MAX10 device, can either the _p and _n of a clock input be used single-ended? May they *both* be used as different single-ended clocks at the same time? If one is used as a single-ended clock, may the other be used without restriction as general purpose IO?
Finally, similar to the question about clock inputs, are there any restrictions when using PLL_L_CLKOUTp and n as one or two single-ended clock outputs or single-ended clock output and the other IO?
Steve
    Hi Alex,
    Thanks for the reply. Just to possible help others, I did run into a problem when connecting the other half of a CLKx differential pair to an output. This case is illegal:
    CLKx n or p as single ended clock connected to PLL
    CLKx p or n as output
    The error is that the output is too close to the PLL. It occurs for any CLKx pair.
    Steve
    You'll have to ask Altera for clarification regarding the performance of the pins not covered pinout. However, you could also refer to figure 2-4 on page 2-11 of the "max 10 general purpose i/o user guide (https://www.altera.com/en_us/pdfs/literature/hb/max-10/ug_m10_gpio.pdf)". This explains the low & high speed banks break out to pins.
    As for your other questions:-
    Yes, you can use both CLKxn & CLKxp for separate single ended clock inputs.
    Yes, you can use one as a clock input and the other as general purpose I/O.
    There are restrictions around the use of the CLKOUT pins. These are associated with a particular PLL and benefit from a low latency path from the PLL out of the device. So, if you use PLL_L_CLKOUTp as a single ended output, driven directly from it's PLL, you will not be able to use is pair, PLL_L_CLKOUTn, as a single ended CLKOUT signal driven directly from a PLL. I highlight 'directly' as it may be possible to route a PLL output signal out of this pin but you will not benefit from any low latency path. However, you will be able to use it as a general purpose I/O.
    Cheers,
    Alex
