8 years agoMAX-10: IP core for UFM
I have instantiated the Altera on-chip flash IP core to use the MAX-10's UFM, but Quartus does not generate programming files since the one of the modules of the IP core is encrypted. I tried to use ...
8 years ago --- Quote Start --- Hi, Can you attach the Compiler report? Elaborate more on the steps and IP's used in your design. Refer below link for more information on Steps and IP licensing. https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an320.pdf Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation) --- Quote End --- 1. Compiler report attached. 2. This design is using Altera On-chip flash memory. After adding the IP using Qsys, I created a top level module that interfaced and instantiated the IP. And I am using standard edition of the Quartus with Open Core hardware evaluation mode enabled.
